Andrew, I’ve thought, (drug and alcohol induced) about another form of your OSSR remote… it would essentially be a giant plate of vagina, that the operator would control, Steve Hawkings-like with their tongue…
whatcha think?
It would have to be not clitorial region specific, as most of these fucks couldn’t find a clitoris with a map, and a drwaing…
Damn straight. That thing is awesome. He’s still working on the design a bit. Currently it’s cold AF in Philly and riding with bulky gloves suck.
It’s called the Taco, it’s sherpa lined and has enough room to hold your remote with no problems. He also lined it with kevlar on both sides in case of a fall. It’s been solid for me.
I went out for a quick run earlier. As I was crossing the street up the side walk ramp the clamps dead stopped me at 5mph. Sent me off running. Really gotta get that sorted. These wheels are a dream though lol.
I had an idea that I haven’t followed through on yet that’s very Jimmy rig but I think would work.
Remove the paint from the hangar and mounts.
J-B weld the mounts on the hanger.
Then cut the excess metal off of the mounts that passes below the hangar.
It would give you as much clearance as you’re ever going to get and the mounts would be permanent.
But you need to get your JB mixture perfect and really cake it on there lol
Or drill and tap a screw thought the bottom of the hangar into the top clamp and ditch the bottom clamp, just cut the head off a screw and file a slot like a set screw
