It’s OK, I’m too lazy to learn French hehe
Good, let’s keep it that way. Makes my life easier
This is awesome
Where do you keep the police radio scanner?
What bad guys have you fought?
Can I have a signed T-shirt?
To be honest, the cage is not ready, still needs the center adjuster which is currently in the works:
@Tampaesk8er on a scale from “polyurethane longboard slide wheels” to “pneumatic all-terrain wheels”, how do those wheels do when it comes to battery range?
I want to try 125mm Trampa Gummies sometime.
I havn’t tested them that way yet, been very busy, not much riding, i’ll let you know when i do.
Which BMS is that?
Looks like one of these generic waterproof China BMSs
Oh, fuck yaaa.
Just wanted to see how it was made after I ruined the packs falling.
Ah the old sk3 wobbly can. Tip. Never run those things without first re doing all the loctite. Especially the front plate 3 philips heads.
Edit; the newer ones do indeed run allen bolts now. My early ones have philips.
You’ve just successfully guaranteed I will never try the sk3 motors.
Once you put thready on them they last forever.
I didn’t know it was a known issue.
Any reason rethreading won’t work?
I run those almost exclusively and never had an issue. I got into a habit of checking all bolts on anything manufactured in china though because QA…or lack thereof.
Its just those front 3 plate bolts that usually come loose so once thats sorted they are tanks. No reason why you can’t rethread though if being loose has done some damage.
Never had an issue… except wobbly can?
LoL.z this is too confusing
Once due to loctite or lack of it which I explained quite eloquently I thought.
Put your glasses on Brian.
For perspective I don’t consider checking and re doing thread lock on a motor an issue. Magnets falling off and bearings imploding yes.
I rarely wear my glasses. Only to drive an automobile or play cards.
