Whatās your clearance like under those motors?
enough ![]()
Itās not bad, the wheels definitely help the clearance from the ground, there was a point where the mounts would hit the board when I turned but I adjusted the angle and itās been good
This kid couldnāt be any more of a mini @rafaelinmissouri. Heās probably on his way to grab an espresso
That little dude is way way cooler than I ever wasā¦
Was it difficult to pull this out of the stator? I have a reacher with 2 mounting screws stripped on one side, but firmly mounted on a motor mount for now. Iām scared to touch it. If I can take out that piece non destructively Iād tap it to the next size though when Iāll get to shuffling it around to another board.
Have you already tried slightly longer screws?
I think the Reachers need deeper penetrationā¦
Yes it was only ever used with maximum thread engagement.
This literally slipped out with minimal effort. Put it back with retaining compound so itās (hopefully) never coming back out. Took all of 20 minutes - but let the adhesive cure fully before putting the rotor back
that was a hilarious mistake
@daegoe that pack is FRESH!
Thanks, man. Itās come a long way from this Loud Pack | Structural 3d printed frame for onewheel battery packs
What the hell, this is the most beautiful battery Iāve ever seen ![]()
Itās so good I couldnāt tell if it was a rendering at first
I totally thought it was a rendering!!! ![]()
Me too
Good to see you put that thing to work!!!
To work? I wish it made me money. No work, just pleasure
Itās a consensual BDSM situation.
The important thing is that you break the board and the board doesnāt break you!!!
Wow.
I come across box turtles every now and then.
But never a dinosaur like this oneā¦
Do you know what kind it is?
