Thank you, Iāll see what can be done when I can move again properly.
Lemmon 714
Looks like you need to run less pressure or wider rims to even out the wear pattern?
This was already at like 15 psi lol.
The real solution is to stop sliding/drifting every time I carve, but I donāt think thatās going to happenš
Is that Shunt from the original UK Robot Wars?
Additionally, is that Dead Metal I see around the corner?
Yes itās Shunt. They brought it out for beating up some washing machines at the end. I recorded a bit if you like.
edit: I think thatās Dead Metal, didnāt have much time too index them in the VIP half time behind the scenes I was too busy talking to them about VESCs and motor kv.
So cool, looks like an awesome track!
Very neat to see so many entry-level thane boards. Hallmarks of a healthy community
yup, everyone had fun. looking forward to hosting more events at that track next summer
AH is ampereĀ·henries
Ah is ampereĀ·hours
Cursed unit.
You also missed his use of Watt-Henries
WattĀ·henries sounds like a more cursed unit than ampĀ·henries. At least AH could conceivably be used in inductor size/cost measurements.
ĀÆ\_(ć)_/ĀÆ
Just for ānormalā rides?
For offroading mostly. The motors will probably scream on those 1:7 ratio drives at cruising speed ![]()
But still way more suitable for cruising rides than the raceboards is, if I put on the 1:7 slicks and the big battery.
Itās getting a 20S1P pack soon, but the raceboardās battery is compatible.
Also eventually some Dualities but that will take a few months.
You can check out the build thread here, will make it up to date after the weekend.
Sick pfp / logo man!
Is that a tiny folding work table? Iāve been looking for an appropriate sized work space for this project.
And where did you find those tiny workshop assistants? Do they get a W-0.2 for tax purposes?
@linsus i have a new appreciation for working with big hubs. The inertia when clamped to my computer desk can tilt it on to 2 legs. What voltage are you running those at?
Yes! They sell them as portable sports team benches.
The esk8 brings the little assistants. Their hearts yearn for the motorsā¦
If you build it they will come. I see, so⦠that is where children come from. Completed builds, I wouldnāt know.
