🖼 Reply to “Pictures and nothing else” thread 2025
How difficult is it to lengthen that shaft to make it power both wheels?
I would assume it feels like a locked diff then too, so it must be made more for speed than turning?
You got my brain on a firecracker with this build holy cow
No it’s fine. The hanger turns and your turn radius is wide enough to not notice any slipping.
Modifying a motor is not that hard if you have some motor and machining experience. It takes about an hour. Basically you just have to slide the shaft out the back side. But to do so, you have to completely disassemble the motor first just to get an idea on how the manufacturer put it together. machine a hole on the rear cap, maybe modify the shaft, And reassemble it.
After I built this board.It only took Stooge three months to copy my motor setup. So it really can’t be that difficult. :joy:
neat! what diameter belts are those Jay and did you use a manual mill?
I might have to try my hand at that, it doesn’t sound all too hard
It looks so much fun to race, And also top out
Have you ridden it much? Looks like it needs some frit
Really depends on the motor. You’ll have to pull the motor apart first to see how it’s put together. The very first one I made… I think it was 14 years ago. I just used a hammer to pound the shaft through the back side. Wasn’t pretty, but it worked. The new motors that are sensored, you have to remove the sensor first or you will destroy it. And sometimes the shaft is keyed. So you have to be careful. Manufactures tend to make little changes over the years. Even though the motors look the same on the outside.
On another motor, I had to disassemble the squirrel cage and machine the shaft for the bearing to slide enough for the shaft to stick out the back.
On my recent motors I used a mill and a lathe to machine them.
10t/40t with 255 belt 107mm wheel.
40mph setup on 8s. 520kv motor at 100%
Or
55mph setup on 8s. 800kv motor at 75%
It’s naked!
what are you doing next?
man that takes me back reminded me of this
Yes we delivered the first production speedboard last week and there other boards 9 are currently being tested and finalizing all the details with our shipping partner’s.
@JaysTCB did you weld this frame?
Was just wiping the dust off of it. And going to add a new wedge footstop.
Originally it was SRB #11.
I modified the frame to add w-concave. Then I made new upper and lower pans.
Then I continued with a bunch of other improvements. I let my imagination go a little wild.
yeah, each deck comes with a sliver of Kaly’s debt
Tool you are using to hold the bullet connector it looks like it’s made of metal and has a very good thermal connection to the bullet.
This will suck heat away very effectively leading to the result you took a photo of.
See if you could somehow hold that bullet in place with something that has less thermal conductivity/ thermal mass
those photos were taken while we were removing the connectors. most of the connectors weren’t pre tinned and looked like that after removal.
Story time please:) I was about to buy these drives :disappointed:
Me too, in fact already have bought but not yet available for dispatch so could probably still cancel. I believe the new small dual gears are metal so that may help. Anyone else had issues? @rafaelinmissouri i think you’ve had a few sets any dramas?
1600 miles, and he rides pretty damn hard so I’d say they held up well enough.
I have had 3 sets.
2 are still going.
1 I retired because it clicked…
No other issues for me.
I just recently opened my first set that I was running with the original grease and regreased it and everything is fine.
I wonder if the metal gear version that’s out now would solve this
