Probably because your intended sarcasm was all too real a scenario, easily seen as being completely sensible by a distressingly large number of people.
Not commenting on that to make sure others knew it was a bad idea would be irresponsible.
Our posts will not always be seen the same way by every person. Understanding that, and having respect for the different viewpoints and approaches others might have, is important. But I know this idea might go over some peopleās heads.
Perhaps there is some way to have a small sanding disk (Dremel?), on a foam base so it conforms to the cell, mounted down like that milling bit that you could pass down a row of cells in a holder/vise.
Essentiallyā¦a safer version of that milling approach. Making it sort of an assembly line. Probably not worth the effort but I always seem to end up trying to think of some way to safely speed up the process. Itās so repetitive so it just irks me that it canāt be faster.
both hands are occupied when riding. right is remote, left is accessory remote to control everything - mainly used for turn signals when riding. Iāll film with my phone for a bit in my hand when riding but I donāt have a mount or stick.
Pretty much everything is detailed in my boardās thread but itās quite spread out. All parts are listed in the first post. Essentially I use a 433mhz receiver and transmitter (generic car remote key fob). The receiver is connected to my Arduino mega 2560 pro which is the brains/OS for all my accessories. Then all the lights have switches made of MOSFETS, triggered by the Arduino.
