Squirt factor: 100
Loved watching the process through your Insta updates. Far out, what a lot of work!
These Semendeeds are pure sex. Perform as good as they look too!
Squirt factor: 100
Oooh I bet someone could 3d print a useful piece that holds a metal jigsaw blade in spot for the motor shaft to spin against.
No, you’re right… Dual wielding power tools was the more kickass move.
I think a jigsaw blade might have a tough time with the case hardened shaft. Youd probably be better off with an abrasive disk.
I’ve seen specific jigsaw blades for metal cutting in case metal jigsaw blade was misinterpreted.
But an abrasive disk would hold just the same and probably would last longer so I concede.
Well there’s a bit of porn… is there a build thread?
Yeah it’s that board, it’s pretty crazy, it will spin all four wheels and I wasn’t even close to full throttle. And the motors sound like a tiny jet engine. It’s my first time ever riding a 4wd board and I have to say it will probably be hard to go back.
And if you haven’t already seen the video, check it out. The commentary really tops it off:
And don’t worry, he came away unscathed!
Doesn’t seem to be playing or is it my browser?
Just tried the tiktok link instead. Maybe that will work
It’s not you. The site is just broken.
Bummer. It’s one of the best eskate stacks I’ve ever seen!
Yeah you don’t usually see someone starfish on an esk8, let alone into the drink
Where are you seeing it?
Wow, you can definitely tell it’s a Tiktok video, how it’s cropped on 4 sides lmao
Yes. Thanks. Must watch with sound on!
honestly those barriers probably lessened the impact a lot do we know if dude is ok? board ok?
