Did you connect it directly to the battery?
I did. Running straight from batt+ to a 48v led latching switch to light source with neg from light going to P- on the BMS.
Awesome!
That’s how all the bikers you encounter will be lol
i don’t actually see that many people on bike, even when there bike path, they like to take the road
what’s that BMS? looks like has Bluetooth and nice form factor, I’m looking for 10/12S though.
Also what does the Arduino do? And… are the fans the most expensive part of this project?
its a LLT bms which i wire it up to the lipo pack, it has ble and app for checking delta balance which is much needed for lipo imo
the arduino is a malectrics welder, the fans doesn’t cost that much tbh this whole box is basically a portable welding station
what enclosure
naah I think they’re die-cast
Those trucks look really nice.
Have you ridden them yet?
Are you using the Bushings that came with them or something else?
Haven’t ridden on them yet, just got them in. Its snowing and icy so it will be a while till ill be able to actually ride them. Bushings are stock.
Ooof! Won’t be trying to DIY that!
I’m sure you could CNC something comparable depending on what geometry specifically you want to copy
CNC would be much better than die-cast too
Yooo that startup music, how’d you get that?
@daegoe Looks cool and fluid.
- What’s the strip? Seems very high density.
- What controller/software you’re using?
