@bboybowzer what happened?
From my understanding from the new owner. Accident and it went full speed into the side of a wall at a velodrome
I donāt know why I find that so funny, itās actually horrifying.
smiling as I say thatā¦Iām so ashamed
same here, i shouldnāt be laughing but here we r laughing our ass off
Thatās badass!
You think it would propel you on a push board?
Thatās some Richard Browning type shit right there
Of course, itās more than 12KG of thrust. Thatās why I make those weird moves
strap a few more on u, and u can fly
You gotta try that thing on a snowboard now
Oh, I just thought you were an incredibly awkward human or super weak.
absolute chad. how much that edf cost?
SchĆ¼beler DS 94 DIA HST is about 1400ā¬, but I got it cheap
Actually those are not the only hubs that you can fit to any truck. Exway hubs fit all trucks with a little modification, a small slot needs to be cut into the hanger for a key. But itās easy to do with a dremel. The thane is of course not as good as otang, but itās not that bad either
They are all bigger than 85 mm though right ? And yeah every Esk8 thane is ass for sliding
85mm. I havenāt actually slided with my exway x1 max yet though. But the thane certainly feels way better than the generic āchina thaneā abec copies. Not as good as otang cags or ahmyo akashas.
Chase Hiller did do some slides on the x1 pro though (previous version, but the hubs are probably not much different) Chase Hiller- Electric Skateboarding on the Exway X1 Pro - YouTube
I certainly need to refurbish my hubs before i can use them again though. Daily driving it in Denmark weather killed those bearings in 2 weeksā¦ Free spinning my hubs @45kph is louder than free spinning my BN M1 AT 5.2 ratio steel on steel gear drive at 10S 170KV, lol
But I want to slide them soon to try how they feel for that. I am still at the most basic slides on freeride wheels in my progression, so I am probably not the best on giving opinions on the smoothness of the slide, but I could compare to purple cags probably. I plan to practise sliding quite a lot during the next two or three weeks.
Also just a heads up, having the ability to change trucks is great because the exway trist trucks the hubs come with arenāt that great. The lean on them is quite limited. I am used to riding cronins, BN270s modded to tall bushings, and matrix iis though so yeah. I like to have a lot of lean
You would need to make a small slot shaped like this, which is around 8-10mm long. The diameter of the round key is asomewhere around 5-6mm. If I remember it right a standard length 8mm axles should fit, although I didnāt measure it just eyeballed it length wise. I am on a Christmas holiday right now and far away from my exway, but I will return home in early January and then I can take exact measurements if you want.
I canāt find any pictures of the assembly on my phone sadly, even though I remember taking some
Other than the key for which you need to cut the slot, you need a spring washer under the locknut and thatās basically it. You also need a āmoddedā skate tool in order to access the axle nut because its quite deep within the motor.
Just remove about a cm from the plastic like that. Otherwise it doesnāt fit within the hole on the motor. Iāll take some pictures in early January
Cheers dude. Iām in no rush for photos, just curious more than anything.
My hangers have a 10mm bore for the axle so itās likely i wouldnāt be able to make them work without having custom axles made anyway.
You are welcome! Yeah I donāt think you could fit them on 10mm axles. Will take some photos and measurements once I am back in Denmark
