Are these the lanyu model?
i found a taobao listing that says 80/60-5 soā¦plz send help
A PSA to anyone who wants their parts to be pretty colors: BUY ALUMINIUM SPECIFIC PRIMER!
It is hard or impossible to show the difference in photos, but holy shit did it make painting this adapter so much easier. None of my methods have changed and the only new thing is that I new that the aluminium stuff existed and took like 10 minutes to find it in store so I could use it and not the all purpose primer. It sprays on and dries with no surface issues so long as you donāt over spray.
I did intentionally over spray on the lattice bits to make sure it got into all the crevices. It only caused minor surface imperfections, which I sanded off. Once I put the enamel coat on you canāt even tell that the area was ever over sprayed. With the all purpose primer, even if I sanded the area down perfectly it would still cause very minor surface defects on the enamel paint.
The can claims that it will prevent chipping on aluminium as well which is good if it is true, but Iād say it is worth the extra $2-3 per can just for how well it has done so far compared to my blue parts. Granted most defects on those you can only see if youāre looking closely at the parts, but it is still annoying for them to be there. The all purpose primer also feels softer than the al stuff does on metal. Not like soft/smooth but a less hard kind of soft.
I havenāt done any spray painting since those parts so I didnāt just get better at using the spray paint.
I wonāt be stripping my other parts and redoing them anytime soon, so hopefully in half a year or a few months I can have a good comparison on the performance of the two different primers. The two enamel paints I have are the same company and line of product so that wonāt affect the results. Although I know that any of the blue parts will likely have more coats of the enamel paint than the red parts just due to the red not having surface flaws thanks to the better primer.
Is your name on the trucks in case you loose them? It is giving me: āmy mom wrote my name inside all my clothesā vibes I donāt think there is anything wrong with it, and just thought it was funny
Link me! I wonder if itās general range of diameter of inflation or something weird.
I must get to the bottom of this.
I could not blame him though, I looked for one for more than a year then I settled for the deck from Miles board (which I still plan to use someday)
Does that mean Chinese inches (5 cun) or FUB (5")?
I was very unimaginative when I ordered them, so I just thought āfuck it, just slap my name on themā
Iām not sure what is better, having no ideas and getting to be able to ride it sooner, or having too many cool ideas.
Iām sure they were limited in what they could do for you though so all my ideas would have been useless
The former
Save the ideas for the next one
But if you say that for every build, then you will just end up with a bunch of ugly boards
I will admit that some of my ideas right now are probably way more involved than anyone else would ever bother to do. The main one right now is making some stencils so I can make any metal hardware have designs on them without loosing the strength given by enamel spray paint.
More text under here if anyone is bored and wants to read more details about it
Wouldnāt take that long but youād either need to be skilled enough with cutting and making stencils already, or know how to make a computer aided design and get it laser cut. Iād just do it by hand since there is no limit to detail that way and I donāt have any software to make files anyway. also my graphing tablet hates to work properly which makes it impossible to use when having two monitors since it wonāt map to just one section of one monitor
Also if the metal gets damaged it isnāt too sad since you can easily recreate the art at least a few times before the stencil is destroyed. Unless you use a thin plastic sheet that can hold up to harsh chemicals and you wash the paint off after using it.
That is a plan for future-future me though. I was considering doing a simple design on the new bracket I have arriving today but then I realized that the design would clash with the planned design for the bottom of the deck and the top of it possibly. Doing it on the top also gives very little room to even see the design.
Iād also need to buy paint that will specifically work best on top of epoxy, and then Iād have little to no use for the paint for any other parts
Is the deck hereā¦
ā¦a seat? ā¦
ā¦or something to stand on?
I believe this is the intended use:
Its a seat, wish i had something better
Are those roofing shingles as grip tape pads?
Build looks dope dude
Thank you, itās insane how good it feels. Itās really unfortunate that thereās no other way to use 165 mm and smaller trucks but HUB motors. Hopefully another company uses ride unlimited loaded hub tech or makes something better
