It says the ones digit is 5 more than the tens digit, so maybe 505505?
Man, and here I thought that was a peltier cooler and you were doing a water-cooling loop to cool off yourself on hot days (DIY air conditioning)
Can I ask though why not just use a regular action camera as a webcam for this purpose?
Al with the W!
haha. i flipped the meaning of that constraint. so i carefully got it wrong.
I thought about it, too bad the pi doesnāt want the same conditions as the human head( warming and cooling) and you would have to separate the systems.
I didnāt want a helmet wart hanging off to get damaged and taking one apart to mount inside probably would have been a nightmare if not impossible.
integrated stuff is way cooler than sticking stuff onto something and calling it good.
itās more or less a cyberdeck at this point inside of a helmet. Raspberry Piās can really do a lot these days.
I have one of those mini wireless keyboard/mouse pads for it. The weak point is the screen at this point I have to plug in a external monitor to view the desktop.
Maybe if augmented reality optics get better/more affordable I could integrate that but for now itās either a docking station to interface or a small battery powered hdmi screen
I wouldnāt have got it without correcting your mistake cunninghams law ftw!
FTFY
Whatās going on here, what project is this?
Del-Rims
Iām using larger dia axles and bearings, so I needed to make my own hubs. Made some out of aluminum in the past but my machining wasnāt the best. So made these out of Delrin. I think they machined better but now I think I need to machine custom spacers and speed washersā¦ they roll well but not perfect so still some stuff to figure out. Made them for the Hoyt St 7ā tires.
Delrin is POM
Ever think it might be your choice in protective gear that results in your constant bleeding? I feel like a full face helmet or even helmet with a chin bar would be a better esk8 decision.
If youāre not bleeding, you werenāt having enough fun.
Full face helmets inhibit the flow of beer, and before you say it, drinking beer through a straw is not an option.
Not sure how much beer youāre getting through that respirator mask. But Iām with you on the beer through a straw
It can be done with a hot dog. Itās a glizzy.
The problem isnāt so much the current flow, but rather that beer through any straw goes all bubbly for some reason
Itās because of the lower pressure needed at the top end in order to convince the beer to flow upwards. The lower pressure also coaxes out the delicious dissolved gases.
