They hit my legs but normally I donāt even notice it until later on I take a shower and find some new bruise that I donāt remember getting
It sounds like the only the outer rubber would be damaged then which might not cause any issues or if itās bad enough a tire patch kit could easily fix it.
If you ever need some testing done on them with roads that seemingly never get cleaned, then let me know and Iād be glad to intentionally drive them through some real world debris for you. I know plenty of areas that are always covered in a thin layer of glass and other car parts from people not understanding what yield means accidents
Obviously it is not finished but the Stooge wheels the back with the 97mm abec at the front makes it look like a mini dragster. Sure Iāll take some vids once completed
Oh, nice, always dreamed of getting one of those, never seen a resin printer in persone, Iāve heard the smell and fumes are much worst than those a any fdm printer which makes it impossible to use at home if you donāt have a real workshop
its not that bad. I have the tiny photon. Has an active filter on the outlet, sure if you sit right next to it its not ideal. But otherwise its kinda meh
Iāve had shards of glass pierce through 5 mm of very hard urethane so I wouldnāt say it is impossible. I think the depth of my urethane sleeves isnāt much deeper than that but I donāt know the exact thickness for them for a better comparison. Also Iāve removed much larger shards of glass before but just didnātā think to measure the piece of glass after removing it
I have my workshop/office/study in a sectioned off area of the living room, next to the kitchen. The fumes arenāt the nicest but they dissipate quickly and arenāt any worse from my experience than using isopropyl alcohol.
