My hands used to be that precise, but that was uh, several broken bones ago. My stains(i mostly use unicorn spit) do NOT like to mix into epoxy, it just kinda makes strands of color instead of actually coloring the resin, so i paint over it cured and then topcoat it. Bonus points as they work to stain glass frit. Oh also, india ink works wonders, but its freakin potent, mix it in a drop at a time.
Esc box
Our sponsored rider was running a fully printed box that attached with the truck bolts. It failed spectacularly.
So this one uses aluminium plates as the base and the lid and will mount through two holes in the deck.
Pretty cool design, I like it.
I can see already that i wanna change some things, but this should be fine to keep him going for now
Dylan?
Yeah. He breaks all the things. I’m surprised the fully printed box lasted as long as it did
Nice, he’s definitely in that shortlist of break everything tester with @poastoast & @Yeahthatperson
Yeeeeeewwww we break all teh things!!
WOOOOOOOOOOOO
I might have to do a ride with my aero lid helmet now LMAO
Wow that is not an easy weld/fix. Did you subtract material by hand or lathe?
Tig weld by a friend of mine (pro scubadiver-welder) its not my world so i can’t be more accurate
This one made me laugh so hard.
Still laughing
Good news is that I found a bunch of skate shops on a nearby city, need to take a ferry to get there, but nothing should get in the way of skating, and this other city has a nice long bike path on the beach, so another reason to go and to stay here one more day
Love it! So satisfying making bits like that! Nice work
Steal his look:
Tags for searchability: magnetic usb micro-b c usb-c remote charging station stand solution quick grab convienent
Take a dremel to it
I actually used a magnetic charge adapter like that on the original OSRR beta units from 2019. At least for me personally, they didn’t really hold up. Lost their strength + gathered all sorts of road grit which interfered with how they connect. It also makes it easier to brick the remote if you accidentally disconnect while upgrading the firmware over USB.
With that said, the model is also open source so folks can modify it however they need.
Does this require a gasket to fit a double stack of 21xx cells?
No, it should be a straight fit with only one rubber gasket
