i mean yeh chinese invented fireworks and gunpowder. just a spot welder not like im using an AliExpress skydiving parachute loll
Of course! Have you tuned the stock kelly controller at all? If you have a batt that can push 300a it can be quite a good controller. The usual stock onyx tune is less than 50% that controllers peak settings. I would swap to a QS8 connectors off batt, mount it externally and throw some statorade in the hub if you are going to up the settings too. External mount isn’t 100% needed but helps with cooling a lot if you are throttle happy.
I downloaded the motormed app but havent had time to play around with it yet. Is that the best one to access it with? I have the 41Ah battery so I’m sure I could drain it faster after I swap out the connectors and get rid of the discharge fuse.
that’s a fucking animal
That’s what I was thinking too. Things a beast.
I’ll get back to you in a few days when I’m back in the states I forget which one I ended up going with only tuned it twice ha
That batt should be good for a bit more juice for sure
Did you change the battery?
Nah, I modded it to take the CyberTech throttle that the OSSR remote uses, aka the best throttle in esk8 hands down. Throttle alone retails for $80
Oh, I see it now!
Has it really been 4 years here?
i wouldnt know a good spot welder from a shite one. No judgement from the special needs corner
Those cable combs look slick af, i am going to steal this idea!
Thanks
@Skyart Is that a qs10? I have one and it’s so damn big. What are the 4 small pins used for on it?
I see your qs10 and raise you a qs12, sir.
No clue what the pins are for lol, i guess anyrhing you can dream up
Dat wheelbase tho xD
I would flip the baseplates on that setup
That would probably give me some much needed clearance too lmao.
Are you using the inner deck holes or the outer holes? I swapped to the inner ones to squeeze a bit more clearance…
Ah the flux deck only comes with one set of holes. I could probably drill out a second set but I would also run into problems with my davega and antisink plate not sitting flat because of the curve to the standing area of the deck.
Ah yeah, duh. That wheelbase is crazy wide!
