Itās really not that bad. If anyone just added a central runout groove to a herringbone gear, the tool wouldnāt collide with the other spur set.
You can also interlock two opposite spur gears and just leave a small gap in between to allow for clearance.
Wust patented a neat herringbone design that offsets the spur pattern so that there is a gap for this as well. Honestly shocked no one has put out a 2 spur herringbone setup with how thin our gear drives have gotten. Bet Apex is on it.
please tell me these will be on your website soon
i literally just checked your website yesterday to see if you had 6355s available
settled for maytechs cause i couldnāt find em but iāll snag 4 soon as theyāre up
@deeznuts_pwned i had one of those, it semeed great when i first tested it then when i went to use it a few months later the welds are absolute shite, no matter how well prepped the electrodes are. Did some research and apparently theyre very dangerously built too - be careful!
Can we please have a glamor shot of the offset drive motor mounts? I know they are every day bargin bin parts (dime for 13 etc ),im just a fan of the asterics. Sweet board!!
it is the magic smoke that makes them dangerous ! I have found that once you free this smoke demon from the said Chineesium electronics ,they are rendered harmless,stationary and not much fun.
Im not sure how they trap the smoke in there but i have gotten pretty good at freeing the smoke demons #freesomkedemons#letmysmokedemonsGO! #fucktaylorswift
What did you have to do to not lose display, turn signals, etc? Been looking to swap a FarDriver into my onyx eventually but there is dangerously little info I can find
Car LED Light Strip, KaiDengZhe Car LED Headlight Surface Strip Tube Light RGB Multi Color APP Control 23.6 Inch Flexible LED Daytime Running Light Strip Neon -2PCS Amazon.com
Iām using these ones that are marketed as headlight LEDs. Just runs off of 12v and bluetooths to your phone. There are an insane amount of modes. I made it to 200 before I quit playing around.
Itās pretty easy honestly. Way easier to tune than the Kelly that comes on the onyx (I have the smaller Kelly 200a kls on my super).
I donāt run a display or turns. Just controllable dual headlights and a rear tail light that has motion sensors so it automatically lights up brighter when braking. For speed I use this app called āspeedometerā screen shot:
There are a few named that but after lots of testing I found that this one with the ā72ā in the logo is the most accurate. It waits while your at speed before showing the current speed. Distance is way off but Iāve never seen the top speed be off not even by 1mph.
Battery I check off my bms app but 20S at 59AH gets me pretty far haha
I have to do some electrical stuff on the surron to do I should do an install/tune video for the far driver. I have to reco just redoing your whole wiring harness. Stock stuff is under spec and just complicates it imo.
