You could cut it out unless you can’t bear to damage the dildo.
I think customs and airline would consider battery permanently attached as long as opening it is not user friendly (aka require tools). in that case, I would take a dildo any day.
w0w just stumbled into…
sum d00ds talking about glass powered electric dildos for singaporian d00ds…
That’s a title worthy quote
What’s the difference between a dildo and a vibrator they are the same ain’t they.
Only Bill can answer that one
The term you are looking for is officanado
There are three kinds of popular sex toys:
- Dildo: unpowered.
- Vibrator: powered.
- Al’s mouth behind the glory hole.
Dildo Gaggins, the vibrator aficionado
Not yet, the video is yet to be released
Is that the bms ?
If so, I don’t think it’s a good idea, if anything bad happens to it, i would be a pain to redo everything in comparison of just plugging the jst and soldering 2 wires
You can just remove the cells easy compared to a normal battery. Only the pcb is not so mutch more expensive then one bms. The expensive part is all cell holders and cells and those can you keep.
Nice job, would it be complicated to make it go a bit over the nose like this
Maybe the angle is problematic?
Would be possible with a small seperate piece, like Jonny used on his thingiverse concave model. But would be a hassle to let it connect with the overhanging part I think. Maybe on a future iteration, would definitely look cleaner
Is that’s what’s in the box?
I can neither confirm or deny this statement
