Just checked. Is 270. Has to be the high temperature one. A good way to tight those long bolts and keep the correct alignment, is to install the motor with the long bolts totally loose. You slide the motor on the truck without the collar bolts. The you start screw the front big black nut on order to give the right compression to the motor can. You stop when the motor is fully seated and there is no later play, but the drag while spinning the motor by end is still smooth. From here you have the right compression and just apply green loctite on the long bolts and screw them in on a star fashion way. Let it dry one day.
Cool thanks for the info. Just got the 270 ordered. Looks like I bent my backplate pretty bad. Luckily I have the spares from my old drives
Once well tighten I never had a single bolt loose so should be fine.
Bro fits like a glove your shit is tight…
i
no delete…
uhhhhhhhHHhhhh
Igotta …
It’d wanna be. It took a lot of beer and swear words to get to this point.
I will try more swearing next time I my although the language in my shed would make a pirate blush…when Jr isn’t there…
That enclosure looks bloody amazing and I’m glad as hell it was left in your capable hands!! I need to do it justice now
Still got a minute left to go my man. Will keep you updated as it gets properly finished, attached to the deck, and then i gotta finish the deck
But i have well and truly broken it’s back. Its been a journey.
As a student working for his exams moved in august, I say fuck you and your happiness
I know your pain hahaha Cheers up man
I’ll send you vibes when swimming in few minutes ♂
Best stickers in the game?
This little art side-project has been a LOT of fun. The artist I’m working with is crazy talented- they primarily do a lot of scifi concept/tabletop RPG artwork professionally & freelance. They continue to nail it though- have a couple more projects lined up.
Besides, nothin worse than skimpy stickers right?
What enclosure is that? Seems tailor made for your PCB.
Or, the PCB was tailor made for the enclosure.
I helped Ernesto with his own PCB. This is my spin on it.
I had that fleeting thought, but it was fleeting.
Beautiful piece. I got a black light 420 tattoo years ago but it doesn’t glow anymore. Been meaning to get a redo. Hopefully they didn’t turn out cancerous.
I’ve had those UV colors sitting around for a while. Decided to put them to use last night.
Also made a “love child” piece for someone on this forum
Oh fuck I didn’t know you blew glass. That’s way cooler. You ever throw your art in the are you artistic thread?
