i cant remember the thread but it needs to be put in ESK8 backgrounds or wallpapers!
Thank you @frame !
Bro that’s T-shirt weather
I’ll go skating when there’s ice outside.
better man than me, if its not 70+ its too cold for me, im not built for the cold.
Y’all burning alive at those temps. It just hit 8 degrees here and I’m in shorts and a t-shirt
Just curious what bms are you using?
Are those SSS motors any good for a mountain board with high torque at 12s and a stormcore or would you say predominately high speed? Seems all options are high KV sensorless.
Not really any experience with them. These are my first, and I have not test riden yet
Part it out :star_struck::cut_of_meat:
Now that’s some straight, uncut, fresh Unobtainium :tm: right there.
Haha. I’m not giving up on it just yet. Need to swap out the motors as the TB ones tried to kill me and then i’ll put some more kms on it.
I made some changes to the bushings which made a big difference to the ride feel, but I need to spend some more time on it before I make up my mind
One day those reachers will make it
Yeah, not easily found, but they are kicking around here and there.
One thing to note, rayne changed the press and cut so much. I have a 2010 Northshore graphic and a 2013 bear graphic, neither fit Al’s mold.
Could have been made to work with gasket fuckery, but the panda fits like a glove.
We just got word. Reacher fucked up and didn’t respond to some customs bullshit so the motors got sent back to them :man_facepalming:
But good news is they are coming express now this time
Let’s see what skatan has for my budget :joy:
I need to take a moment to defend my skimpy D-seal gasket :blush: On a flexible, fitted enclosure a little D-seal goes a long way. I ride through slush and slop all of the time and the water has stayed outside of my enclosure, where it belongs. I also use rubber-backed, sealing washers to keep moisture from infiltrating the bolt holes. :sunglasses:
I was wondering why the bolt holes were inside the seal :smile:
Nice.
Have you tried butyl tape?
I’m open to ideas. Ultimately, I’d like to do custom gaskets for them.
Man, Rocinante is faaast.
