I want to do a high powered 2nd build
Inrunners are a nuisance in this area but have much more power
I tape half dead boosted guts on stuff for test drives xD
Omg tht just opens a new world for me
So i just did a little math. Aps also has 56123 inrunners 400kv max amp 150 and max volts 90
So when i use a 16s setup with 4x4 16000 mah in series i could use the stooge race trucks an encoder and a ubox as vesc. With the 11/78 gearing i still would have insane top speed and high torque on smooth motors am i right?
I want to go 16s with lower amps on the wires so get the power and torque from the gearing and the higher volts. Opposide of stooges setup
Am i right with my thinking?
I know the ubox has its limits at 100a per channel but i think this would be pretty nice or am i missing smthg?
I was running dual 56114 360kV at 12s on 1:6.25 gearing with 8ā tires. Startup torque wasnāt the best (not enough for my needs off-road) but they really took off at like 20km/h.
With 4wd the 56123s 1:7 gearing and maybe 155mm tires that should be pretty good thou.
Ok so the 11/78 gearing is like 1/7 on 150mm wheels should be pretty torquefull and insane for uphill or cart track racing wht you think?
I donāt know your weight
but should be a good setup.
Im 85kg
Thx very much for your input
So one more thing
By using the inrunners with a vesc is there also reg braking possible?
Same as with outrunner. You will have a bit less braking force compared to outrunner, but thatās relatively easy to fix with higher brake settings. Shouldnāt be an issue at all with 4WD.
Ha nice i only see benefits from this at the moment
May i ask which battery esc setup you run ?
Looks like those trucks wonāt work ![]()
The wheels actually fit on the truck just fine itās the wheel bite Iām worried about LOL
Lol tht looks funny
thatās why they wonāt work
Thatās fucking awesome
G Bomb & golden! it was really just a joke, they are for my trike.
it started as a joke but i have almost convinced myself im going to make it work on a build in the future. just because why not.
Standard V4 reacher tech (and subsequent V5) have recessed the bearing to be flush with the mounting plate. Theyāre no longer a massive PITA to use on our esk8s.
Now go forth and scratch it up and get it muddy ![]()
Iām currently shopping for new motors, should I consider reachers?
