sounds good, but sounds perfect electrified
Oh damn, those decks are hella strong
Let me guess u put danny on it
Don’t be playing like Ohio didn’t invent crocs.
Is that a pic of the deck flexed that deep or is the ground clearance that low even with 110’s? It’s hard to tell
frantic panicked googling
Oh wow haha that is indeed impressive. Did it creak or make any weird noises lol
Also you missed your focus for the background blur
char char
Yesssir
That’s pretty sweet!
I’m running a single drive right now with a sealed Maytech 6374 and it’s getting pretty damn hot, wondering how much better the SK3’s would work for me with superior cooling, and no sensors.
The motor is getting hot, or the ESC?
Usually my FOCBOX 1.6 overheats before my motor, currently a TB6380 but was a sealed Maytech 6374
motor for sure, esc can’t get hot it’s getting some airflow I think it stays under 60-70C, I’ll check next time.
The motor gets over 80deg I start getting faults and feeling it limit power, its very hot to the touch can’t keep my finger on it too long. I just wait and spin the motor some and it goes back down to 60-70deg in only a few min.
on my last ride during the break I searched and it seems that sealed 6374’s are rated up to 100deg.
Would be interested in trying out a single drive 6380 maybe I can borrow my buddy’s lol.
He’ll just need it back when jason hand delivers the unity.
Why even leave the connectors on there?
I’d honestly be stoked if MFRs made VESCs with large solder pads/rings less connections means mOaR bettererer… you should have seen the wiring nightmare that this design precipitated…
It looks moAr betteter not seeing the solution… Only the final product…
My current guess,
is that the pos/neg wires are each split into two bullets that go into the xt60s
This allows a double sided parallel connector to be made in a much shorter space than two male xt60s end on end.
I’m feeling the smartz although it might be what i’m smoking
I think he meant why have the XT60s at all. Just solder the wires together and exit the contraption
Both solutions work fine
I fully comprehend compadre… My thoughts are still valid…
