Can you snap a pic of the front and back as well? ![]()
Where did you get that copper strip?
These take forever to arriveā¦
On aliexpress last year. I bought sheet and cut to size but yeah strip would be much better
btw, the piece in the middle is actually Beryllium copper (BeCu), the other pieces are Cu/Ni.
Why Beryllium copper? It can flex without breaking I was interested in itās properties but itās a bit too thick.
I have some silver coated Beryllium copper wire which I may use for a tight upcoming situation where I need to split a parallel packs into two parts itās typically used as spring wire for high ampacity cell holders, but yeah Iād pick silver coated flat copper braid in that case if there were room.
Materials nerd wasting $$$ Also you should avoid licking it, quite toxic
Why not just use single 6Ah pack?
Because more parallel packs= more pixies to hammer home the weldā¦just like an esk8
Each of those 1.6Ah packs was only about ā¬15 - Graphene Panther, they work nicely and donāt get the XT60 too hot since they share the load, if I try to configure all of them 4s4p it actually gives me an overcurrent warning, thatās why I can stick nickel to copper, in fact I can use just 2 and have 2 in the layby
But yeah this will weld for longer for another ā¬30
Do you have a link for that? Do you have any extra? PM?
āI have shoes and a helmet, I can do thisā ![]()
Good work!
Freakin 5year olds
Has no shoes
Are these 0 degrees RKP baseplates? Like one could use this on a angled tip carver? Can you use them with SR hangers?
The Haero Bro is such a nice deck.
15 degree bases. Going on a tipo or a bro deck. Maybe the bro deck because I like the feel and weight.
Also space for a smart bms and im feeling the forged carbon fiber enclosures
No to the SR hangers
I missed the part where you got the Bro deck. Everyone seems to love it, I just donāt like the hourglass shape for no particular reasons.
What is a forged carbon enclosure?
Got it in a trade deal
You are on all the good dealz its disgustingā¦
Love the enclosure, really nice is it called forged like damascus steel?
Are there specs for your hangers or a thread ?
Bro, do you even Bro?
