Thatās because a VESC 6 is a trademarked productā¦
It can be V6 hardware and not look anything else like another produced based off of the same design. What makes you think it looks nothing like V6 hardware?
I was being sarcastic actually. Sorry no /s mark
Oh haha. Sorry mate I missed the joke. I am careful to say V6 design/hardware rather than the other word
high resolution photographs of the circuit board, both sides, would be super dope
What wheels & tires are those?
Thatās @MoeStoogeās new setup, isnāt it?
Dont forget the halloween2021 discount code, gets you 20% off
In theory it should be a v6, and we will find out soon
Im limited to my s20 ultra phone camera
Dang it, im picking them in the morning, too late for me ![]()
Removal of components by designing a better system. Instead of just adding to over come the issue. Less to go wrong less matanance resulting in it lasting longer costing less to produce. Only realy pays back thro quantity tho as design time costs a lot more than a fan.
Usually I would agree.
If there is a particular shape/size requirement though then it might not be possible to add a fan. Fans might also require a buck or boost converter to get the right voltage to run the fan. This takes up more room and adds to the parts cost.
You also need the mounting hardware and the fan needs to be added manually to the PCBA (which often can be 100% machine-assembled otherwise). This also increases costs and assembly time.
Iām dealing with this exact set of issues right now with a product Iām working on. Adding a fan allows for a higher power rating but increases size, cost, and assembly time. Or, the fan can make the unit smaller (if the power rating is not increased) but it adds cost. So many things to consider trading off!
Adding large oversized mosfets and other components to produce less heat is also adds to cost and space itās all a big balancing act.
Iād mutch rather a well designed product thatās balanced than a cost orientated one of x part is cheaper we use that
You already got them? ![]()
yes lol, any in stock item on the hobbyking website is a next day pickup for me
I expect a model photoshoot of the ESCs by lunchtime thx
I am so jelly but I would be a platinum member if that was the case
let me whip out my imaginary dslr and have a go at it ![]()
u have no idea how tempting it is to just buy from hobbyking instead of waiting for my taobao order
I know a couple peeps on here used to be platinumā¦
Iām not normally a fan of clear grip tape, but that actually looks really nice on the Bro ![]()
Wait a second⦠That case is injection molded plastic, and that little heat sink is all the heat sink there is?!
No wonder itās so cheap. Those product pictures on their website look so slick I couldnt tell that the case wasnt metal!
I would be shocked if that thing can live up to itās 80A rating with a heat sink that small. You gonna put them to the test Michael?
