Hahah thank you, it was a beautiful wedding! This was one of our teaser photos, I love it.
Congrats! 10 years is no joke nowadays.
Lol ābig dealā huh Mr. Famous
Thank you thank you
I got it bro ![]()
Thank you thank you
I got it bro ![]()
Nothing dude, iām just a cunt
waitā¦i also forgot!
Congratulations man! a big milestone in life, wish u all the best!
how many connectors is enough⦠it would be so damn yellow if you used mr60 motor.
looks like you have FOUR enertion bt dongles???
Haha its a mess in the esc compartment. Will be worse when I add the bms + batt connector on top and phase wires. Antispark is underneath all that. Keep it neat enough I can screw it on lol.
BKB $2 blutetooth
how would you tell the signals apart?
Go down the list and hope they donāt switch around, or interfere with each other.
Iām hoping the bluetooth mods will keep me out of the enclosure for a while as I want to play with power bias to front /back on the fly.
I was under the impression that you canāt do that via canbus. You running split ppm for front and back?
Edit: and in that case surely you would only need 2 dongles?
lmao hope you are using a freesk8 remote not a flipsky
I think any split PWM setup is unsafe even if split front/back
too easy to have some lose connection.
Two receivers and canbus.
Plans are PPB but I only have one reciever for that so I might just use the shitty mini remote. Maybe I should get another receiver now or pick one up in PDXā¦
That may be, but its my understanding that via canbus, the slaves just do whatever the master is doing
Can a puck pair to two receivers at once?
Donāt know. I donāt see why not but I didnāt look into it. Perhaps their frequency hopping thing might interfere? does it do that?
@DerelictRobot know anything about this? 2 receivers one puck? worky?
No, because the engineers that designed it did so correctly.
This exact argument is what makes ādual receiversā so dangerous. Split PWM is actually considerably safer, canbus more so.
Thank you!!
No one. Thatās the problem.
You cold-hearted bitch.
Whatās the name of those fancy connectors?
Weipu SF12
