less force on each tooth due to greater contact and larger radius means less torque for the tooth contact area.
I use @cfelzien mom as a jizz bucket.
What can I say, I’m the only one she didn’t swallow.
I was just outside unfortunately soaked quite deeply.
good water intrustion test for the board, it failed.
oh and a fantasic excuse for my washing of the gear. it would have smelled and was quite dirt covered.
130MM way too big but fuck I was a set. Shipping Fee will be insane.
yes bro I need to see them with the ring light shining
@Fosterqc hotglue comes off easily if you dribble some isopropanol on it ![]()
I was asking if it is useful for other VESCs without BT. Would be sweet if @DRI included a adapter to use the old module with another VESC
road crap gets into the chain and causes a grinding paste, buy a couple of 10 tooth bois they can wear down reasonably fast
Will be added today.
4wd super single?
Nope new davega thing they show on dual vescs each side separate.
Firmware 4.04
Yeppers.
I’ll be getting a couple extra pairs.
Luckily they are cheap from china
damn thats disappointing
Would you add massive risers in the rear to make up the gap? Interesting idea
No, small ones.
@3DServisas Short shaft to work in your geardrives without modification?
Short shafts are not a problem, if you know what I mean
