The basic specs match (there are other specs though, which might be important) but youâre replacing caps that are at least being used in products with caps that we know nothing about. They might work or they might give out quickly or be badly overrated.
Buy decent caps (the ones he linked should work) and install them so they canât vibrate or be bounced around.
I donât think theyâll fail quickly. Those Amazon ones however could potentially fail earlier than good caps, some time down the road. That would expose your ESC to voltage spikes and can lead to unpredictable behavior or ESC failure.
Always good to do a initial test with as safe a setup as you can though.
I thought that too. Squeezed out the whole tube and let it dry. It feels how it should, just without the black. I wonder if they forgot to add pigment or something.
