I purchased a linnpower ox. The only choice of tires is a slightly under 6 inch stock. I purchased the 66mm wide rims and the tubed racing tires. On the stock 55mm wide rims, I will mount 7 inch novas
When the wide tires wear out, I am open to many replacements.
8 inch 50mm wide Novas stretched.
8 inch flat tread linnpower tires meant for those rims. 8in Wide Tire
7 inch novas stretched.
I am thinking a stretched 8 inch nova will be about 7.5 inch and have good turnin as it is hard sidewalls and stretched.
Or the 7 inch novas that are stretched to wind up about 6.75 inch. And have sharp turnin.
Any other suggestions for a tire to mount on the 66mm wide rims?
There is also the possibility of the rubeless tires running tubes.
One of my buddies run stretched novas and they don’t like it. He gets flats all the time. I think from the wires when carving hard. I also have an ox. I’m thinking about doing the off-road exway 200mm, the 162 semi slick exway, or 8 inch slick cst from trampa.
I’ve got the same 66mm wide hubs on my Evo . Every tire I’ve ran on them I’ve had zero issues with . I’m a big guy and carve pretty hard .
8” Novas
190x50 CSTs
175x50 AliExpress scooter tires
XCELL RS V2 165MM X 62MM slicks
I’ve got one flat in 1,300 miles and that was on the slicks when using the wrong size tubes 150x50. For longevity it’s the Novas hands down but my favorite all around tire would be 190x50 CSTs .
