I’ve been having some issues with my Flipsky 6374 10mm D shaft (Propulsion Boards Edition) and I’m looking to replace it with a key way shaft. Does anyone have a replacement shaft, have a burnt motor, have a CAD drawing of the part, or know when I could get a shaft?
OOPS, I have the other half of motor.
Out of curiosity, if replacing shaft. Theoretically you could take a shaft from a 63100 or similar and do single motor 2 belt right?
I’m assuming u mean to use one motor, right? I’m confused.
I’m confused, what does this mean?
Yes, shaft from a longer motor, out both sides. Narrow trucks, 2 mounts, 2 belts, drift board ![]()
I would but I kinda like getting use out of both sides of my esc and using both motors ![]()
Would be cool tho!
I mean,you could do with both and do 4wd with two motors and 1 vesc if it worked? Cost saver
sorry for derailing tho
I have the other major part, I only discovered that when I looked at my operable flip motors.
Good luck removing the FS BH grub screws and shaft.
any tips?
3.3mm or smaller drill bit, Mineral spirits or something to get rid of loctite. Somehow not damage the grubs hex removing the loctite, maybe a drill bit enstop.
