Removing pulley grub screws!
If you’re going the drill the screw out method, just go straight to the angle grinder with an abrasive wheel. Or a beefy dremel may work.
Try to mark your depth really well so that you don’t hit the motor shaft. I’ve done this more than once with great results, drilling is a fucking pain. Wrap entire motor in a few layers of painters tape, put cloth around & hold in vice if you have one.
Is there any gap inbetween the pulley & motor can? A good gear puller is usually all that’s needed even if the screw it torqued down…
If you don’t have a torch, you could try a stove burner if you have a gas stove. Soldering iron def just wouldn’t transfer enough heat.
If the pulley has two screw holes, putting two socket cap screw or w/e in & using your gear puller on those is usually an option if there’s not enough of a gap between the pulley & motor.
heat with fire
you sure that’s not 465C?
260°C
You could be a real man and grind it off >; ) jk lol
Umm, no
@esk8noob, small recommendation for you….Do not become a cancer and offer bad advice, even if you think it’s funny.
Blowtorch will conquer any loctite in a matter of minutes. Just be careful not to melt any bits on your motor.
I keep a damp rag nearby to cool the shaft down after i have successfully removed the pulley.
i heat the shit out of whatever, then immediately dunk in the sink with cold running water soon as i get it off
sorta hardens it as a side effect
Do you think I should still have a battery terminal puller to do the job right?
I don’t even know what this thing is, but its all i ever use
Anyone else know what this is called?
Tack Lifter
General tool for pulling nails/staples/rivits etc
Auto trim removal tools
Post a pic if you’re still having trouble
Doesn’t work that way bro. Not enough carbon in the material. That doesn’t harden it at all
:face_with_peeking_eye::flushed::face_with_spiral_eyes:
i can DREAM herrald!
