The battery level does not work on my remoteVX1
Has anyone had a problem?
Check to see if any wires have come loose on the receiver end since that’s where it’s getting battery voltage from. Or if it’s even hooked on at all
Did you hook the blue wire to the +side of your battery
I think it’s blue
All three wires are securely connected to the receiver
I do have a blue wire but I did not connect it thanks I will look at this
Ahh thats what I meant 🤦 should’ve been specific. Thanks @Stephensound
Mine is white, but ya it should be labeled V+ or something, that needs to go to the battery positive on the receiver side otherwise your level readout won’t work. You will also need to select the battery voltage, I believe the default is 10s
They have diagrams and instructions here. Be a Flipsky lover or hater, but you can’t deny this video tutorial ain’t cute as fuck
If I’m feeling a bit silly now I should have looked thank you both so cool
