Gave the ends a snip. With my boardnamics Mount, the motor would not fit. Now I am running a 300mm vbelt and really close clearance to make it as low profile of a board as possible.
All that and yet, I still have not recieved my bms, charger, or copper for my nese modules. Had purchased all that since my last update, and yet it is still not here… such a pain.
Been up to 18mph on the board (29km/h) and feel very little to no vibrations from the deck compared to what would be expected from aluminum. Very springy compared to my last wooden board. 42” oats deck.
The board weights 15 lbs all up. (6.8 kg)
So it’s nice to travel with.
I might add, if anyone has extra esk8 related stickers that they don’t want/need, hmu and I’ll add them to the collection. The backpack is looking a little… empty
@MYKC
Using lifepo4.
Nese modules.
Padded with thick foam, and will be lined with fiberglass to stop the flames if the worst came to fruition.
Unplugging does nothing.
In fact, I power the board unplugged, then when I’m ready in plug in and ride. It unplugs when I want to travel, or, fall.
The worst thing that would happen is I plug in the connector wrong and the board goes backwards lol
Check out chiboards who has a much more impressive backpack. I think he’s running something like 12s8p, power supply and bms encased aswell. Or maybe that’s the wrong guy I forgot.
Finally got my bms today, only took 35ish days.
Made a plan to have the bms act like a hobby charger setup people use with lipos with the bms being external and balance wires in a vga computer port. Esc and charger sharing same anitspark xt90, keeping the battery slimmer and more room for padding
Also recieving keybak for the phase wire lead tomorrow.
Exciting stuff! Problem is I can’t charge it cause my power-supply is stoned at HK rn
