Help
Help
Could be broken motor, lose phase wire, one focbox or one side of the unity died. If single focbox check the canwire. Or its just software bug. . Check for that!
Okay thanks
Keep up if it helped. After you checked the wires and the software (maybe try flashing new fw or reset) Check the vesc pcb/s if there is anything suspicious.
Unsoldered
i was having the same problem and i believe it was a vesc issue
There you go
How can i fix it… not much of a DIYer
While you’re in there, re-strink these. If they touch while you’re riding you’re going to faceplant and you’ll just be another person on the forum with the thread about unity failure
Ill use hot glue
just solder it. Its not that hard. Just buy a 10 bucks solder iron and get good solderwire not the shit they sell with the iron. And its fixed in 5mins.
Hot glue is not as good as “GE Silicone 2+” in the paint section of your local home improvement store
But for those, heatshrink is much much better
Dont do that. That will not work
lmao alright
Glad i found the apparent issue tho
Fuckin first ride already got issues
Yeah and check also for what @Brenternet wrote. Just use some electrical tape if you are not much a diyer but rather use a shrinking tube. But the phase wire you have to solder or someone you know will solder it for you maybe.
Electrical tape will leave a nasty adhesive residue like duct tape does.
I think cloth wrapped around it with small cable ties would be better than electrical tape, if heatshrink is not available.
Fuuuuuck i wanted to ride it today
