IDK, @MoeStooge said to put the HD setup through the ringer… I totally have my doubts, both on the trucks actually holding up and on the open gears. So far I’ve been hitting jumps, going through the mud, going through gravel, mulch, etc, and somehow may have held up!!!
I’ve been expecting any minute for something to get caught in them and me to go flying. However that is not happened. Knock on wood.
I used a 1040 for my mountain bro build with a 100D and was pretty happy with it. A 1050 shouuuuld give me enough room to squeeze in the new dev robogatchi
Next things to do:
Go from 12s to 18s
motor swap to reachers
Questions:
Radium vs SKP, what’s the difference in comparable motors? I think I’m leaning towards SKP
SKP 6495 vs 7490 - 6495s look better to my eyes. IDK which I’ll go with. I’m concerned I’m going to get ferrous rocks inside them. I think I did this to @bboybowzer older (?) Reachers
Ik I’m late but the 7490’s have a ton more rolling resistance than the 64xx motors do. They’re also quite a bit heavier. I would consider 6485 138 or 151 kv. I’ve been experimenting with different setups and though I haven’t gotten any motors at that kv yet, it theoretically seems like the best. If you’re a heavier guy like me opt for the 138kv to keep heat down but if you’re light, 151 kv should be good as long as you don’t have super top speed gearing.
Thank you! I’m not sure yet on which I prefer more, I’m still doing a lot of comparing and contrasting and switching back and forth.
I know if it’s actually riding through the streets of Seattle, I definitely prefer the pneumonic tires, they’re less jarring to my joints and feet and add that little bit of cushion.
The BRPs are a lot of fun off-road! When I go in on the throttle hard I can get them to break loose while riding and throw giant rooster tails which is hella fun, and a little bit sketchy sometimes going through turns… But it’s getting fun kind of pushing the limits of powering through turns, getting the rear to brake loose a little bit and getting a little bit of drift going around corners.
The pneumonic tires, being a little bit thinner, tend to sink quicker in mud or really loose gravel where the BRPs tend to float over the mud or really loose gravel a little bit better. Oh and the BRPs look fucking sick!
Once I’ve done some more testing and comparing contrasting the different setups, I plan on putting together a good comparison of different terrains and ride styles in which ones perform better in which scenarios
Ok, some carnage @PedroMcJimenez !!! But this one is on me for not lubing probably… I’m a bad bad unicorn but I learned from @fessyfoo that I should lube lightly before every ride… So I will start doing that!!
Holy shit! I’m going to hazard a guess that something got stuck in there to do that damage! I dont lube my gears either. But i also never go offroad with it.
If you wouldn’t mind sending me your PNW ESK8 bigfoot artwork I’d love to work that into this winter’s project - you know I’ve got that thing for edgelit.
Also, consider cutting the driven gear out of Delrin - the steel drive gear will last a lot longer. Though the kind of torque you push (especially at 18) might tear it apart. Maybe you could get away with it if the driven gear were the same width as the drive gear.
What pitch are those gears? I’m kinda tempted to try that setup when my chains wear out
