2023, ZESC family has a new member, Raiden 7-PRO.
Bran new design pushes continuous current to 200A.
Aluminum PCB makes heat transfer more efficiently.
Water block keeps temperature below 50C under full load.
Click link for more details.
Raiden 7 PRO | Zesc (discoverzesc.com)
Thanks.
Wow that’s some crazy vesc-ing
Really glad you’re using screw terminals. I hope all ESCs move forward with them.
Do the people giving me a thumbs down not realize you can also solder the connection once it’s screwed down.
Unless wrong materials are used, there are zero downsides except. What, 3mm-4mm space in height?
…you can also solder to it without a screw at all, if you so please. You can make that entire screw hole a big solder pool. Options people.
