If you get some .2mm you can add extras if needed to make sure there is no axial shaft play. You want ones with 12-13mm external diameter.
What if i want some shaft play though
Then you might have to order something custom😄
@Trance_End i know you could get those clips in a multi kit with different sizes. I ether got it from like a harbor freight or Amazon. They like $20 or less.
Haven’t had much luck getting my motor cans working I should have took a short clip but after putting everything back together and starting it up and testing the motors it seems to struggle to stay in sync with my working motor
Kinda makes a reverberation as the motor can spins. I notice the slightest play on the motor can at rest and that its fairly easier to pull the can off so not sure it lost some magnetism
I saw on your site that the 138kv motors are out of stock at the moment but my revision is different so likely if I consider replacing it I’d have to replace both even if it’s the same Kv
Any way I could possibly send my motor for evaluation to avoid getting new motors?
I’ve been really missing riding the last few months
Hey mate, I’ll PM you and we’ll figure something out to get you back on the road asap.
The batch 7 and onward motors are no longer compatible with previous versions but I have some spare cans kicking around.
Worst case we’ll give you a discount on a set of the new Lacroix edition. 138kv are in stock - Motor 6485 - LACROIX edition – Radium Performance
You guys are awesome thank you so much for your help. I totally forgot you had Lacroix Edition motors on top of it they’re 138kv
Excited to get back on the pavement!
No problem! If you need any other help you know who to ask ![]()
