Lol. I meant at King’s island.
It was a ghost town. Longest we waited was 20 minutes which is crazy when you consider half the seats were closed for spacing. The lines flew by because they weren’t so crammed tight.
Tried metroboard 155mm tires for the first time today; blown away with how good they feel!
I see why all the race-bois love them so much - grip is amazing and they roll smooth like irish butter.
Consumption shat the bed on the other hand, was touching 50wh/mile on the faster sections.
Pumped to 36psi. Is there a reason their pressure rating so low? Do they blow up at 50-60psi?
Wondering if higher pressure will improve my wh/mile, it’s kind of a deal breaker now.
50-60 works but we run them low for max grip. Higher psi will lead to better wh/mi
I’m running my metros on widened hubs at 40-45psi… I like a slight crown on the contact patch
I tested them at the shop at 60psi… I’ve never ridden with them pumped that high… but I wanted to know…
I too was curious about the low PSI ratings… metros have some of the thickest rubber I’ve seen in this size class…
faaaaaaak wh/km they’re that good…
As it starts raining here again…or better for the last few days
Really. You can run them that high?
50 seems like a big jump from 36 and 60 seems like a really big jump.
Maybe I’ll try 50…
Yep…
My days of lunch break rides are on pause…
Heat index over a hundred make for not fun rides when you are out there RoboCoped out…
Just night rides for me right now.
Some dude on Facebook who I told to get some was running them at 65
I failed miserably in the last few weeks. Still alive.
Seems like you need to use that unity me and Robin sent you
To the bench now. Now that I’m not riding anymore.
PM who to send monies to.
Nobodies ![]()
The “Micro floor pump” doesn’t leak when disconnecting the pump from the valve? Thinking of picking this up, still recommend?
Did some 24 hour store shopping earlier on my fairly basic transport/rain rig (eLofty/Boas/Hobbywing/10s2p Santo 20700) and even that is fun in its own way. Silent gliding on a damp/cool evening.
Yea, it has the stupid bleed button right on the knurled part, not a big deal, just a bit annoying.
Great pump otherwise. Get the high pressure one, not high volume.
good call I probably would have bought the high volume by mistake
Did a short ride today after 2 weeks without, every time I go out I only get pissed instead of relaxing due to seeing a lot off dumb asses in groups and without mask, at this rate we will be in this not oficial but everything closed quarantine for two years
Also I forgot to charge the board and only did 7 km, and on top of that no logs since the permissions for Metr were wrong, not much lost in such a short ride
