Question for this Enclosure.. Boundmotor
I want to get this enclosure for my Moose board. I’m not sure if the enclosure will fit right. No joke… They look the same. The only issue I see is… Moose board has a slight curve at the bottom. Also, I don’t know if carbon fiber is flexible too.lol What kills me the most is… I can’t do return.lol Anyways, the dimensions is very close. This could save me madd money.
Here is the specs:
Boundmotor Octopus Deck dimensions is 39.4×10.2×0.59in.
Moose board
Length: 39.8" . Wheelbase: 32" . Nose: 1.75" . Tail: 1.75"
The dimensions is very close.
enclosure:
https://boundmotor.com/product/12s8p-battery-enclosure/
If you want to know the price. Moose board is $55. Boundmotor is $289. Do you see why I want to know if it fit.lol
My second option is this deck. They look close as heck.
website:wholesale blank drop down longboard deck Blank Longboard Decks and Skateboard Supply
This will be the cheapest electric skateboard that holds 12s 8p.
Looks like nothing a big gasket can’t fix :wink:
Anything can fit. Just keep sanding.
Any updates on this? I am looking at this as an option myself.
After my test. It doesn’t work. You need flat concave deck and 39 in for length. I decision to buy the Boundmotor deck and enclosure combo.
:pray: Ty bro. I ended up buying the same enclosure & deck combo (didn’t feel like drilling and attempting to make things fit together). That being said, I’ve got a rayne demonseed in my cart and I’m tempted to see if I can get it to work. Seems pretty flat.
It’s not going to work. Lol The drop deck is 1.75 inch and the deck is wider than standard longboard deck. The red outline is my old deck. The green corners is missing material to screw the enclosure.
You will need to get a custom deck thats flat and wider at that section. Just get the combo and call it a day.lol
The boundmotor octopus looks like a rad deck. IMO one of the better decks from a mass-market esk8 brand. Makes me think of a mid-sized Red Ember 44.
The demonseed is 9.76". The enclosure is 6.941" according to the site. The octopus Deck is 10.23". I believe you though. I’ve already ordered the octopus kit with the deck. I’m also in the process of building a new push board since my old downhill deck starting to crack, so if the demonseed didn’t work, I was just going to use that.
It’s definitely looks like a nice deck and the kit should be easy to work with. They have me a coupon to use as well which shaved off $40. I’m throwing the bkb type r components inside. A $1300 DIY kit bash build.
Oh, my local shop actually sells their own custom drop decks for 120$, is flat, and the width is 10" exactly. lm going to just run over once my octopus kit arrives to see if it’s a fit.
Agreed. I just skinned one and it seemed to be a fine deck. Concave probably a little too aggressive for my liking, but still a very nice offering.
