i have a small 12s4p flat pack that i want to sandwich in the enclosure of the flux v1 deck, surrounded by foam to secure it and allow for the enclosure to close. I see there’s minimal flex on the enclosure part ; is this a bad idea?
From this video of me jumping on 3 different points of the deck to check flex, stance 1 barely flexes the entire enclosure at all, the whole thing sorta just all drops down instead of bending . i’m thinking its fine? - im ~190lbs, another 260lb rider would also be on it.
i got a different segmented battery for it but I’m trying to run a 12s setup with this pack, would be easy plug in right now without having to make/rebuild the pack
Depends how precious you are. Couple of bits of hardwood, some bracing ply and a generous slathering of silicone could see an enclosure knocked up within an hour
