the D is 5.5mm and shafts are about 19.1mm long
reversed cores on the TB110s makes so much sense because when I push them in from the wrong side they fit way better.
They are slightly too short then, I think for that core. They need to be 19.5mm and 20mm to 22mm is much better.
Can you put some heatshrink tubing on them? I bet theyād be tight then.
then why do they fit so much better from the other side then? Iāll try the heatshrink
My length measurements arenāt perfect BTW because I canāt angle the calipers properly to get a perfect reading, so my measurement might be off there.
@b264
This is the best shot my shitty iphone will permit
Is there a plate in there before the bolts or are they bolted straight into the core? Iād suggest a spacer.
I havenāt manage to get spacers for now, Dicky suggested the same thing when I showed him the photo
Is it recommended due to the vibrations causing the bolt to loosen up?
You just need to spread the load so that the core doesnāt get damaged.
What tool do you guys use for these pulleys? Arbor press?
No just your hands.
Holy gorilla grip Batman.
Is it supposed to be flushed all the way? I have well had bkb pulleys on mine before and I canāt get it to go all the way in.
With kegel I didnāt have any issues. It is plastic-metal contact
Sometimes I use another wheel and hammer it in like a rubber mallet. Might be frowned uponā¦
The only one Iāve found I couldnāt get the bearing into ny hand was the 3d servitas one. Which is a good thing.
This is exactly what I did.
Edit:
I actually did use a rubber mallet.
Get a socket that matches the size or the outer race of your bearing. Pop the bearing in the freezer for 10 mins and then tap it in. Tap tap tap it in.
Share as in not overtightening any one of the nut over the rest is it?
I tighten them up until i feel a resistance and then go around tightening all 5 bolt a little bit more so I guess thatās even?
If anyone has an extra BKB kegel pulley, lmk
Tested out on a 20 km ride yesterday and none of the bolt/nut came loose so I believe itās all good
