Super, I’ve seen it hurt people
yup.
I tried to limit negative erpm to 5k and I got that jittering you mentioned. It was an awful ca-chunk, ca-chunk, ca-chunk on spin up. I thought my gears were binding. It was baaaad.
I’ll try 20k next and see how it works.
My experience was a little less violent, but I was only on 15s I hope the higher eRPM limit smooths things out for you
So too complicated and dangerous to actually look under the shrink wrap or actually use a multimeter. Keep’m dumb.
They shouldn’t call u folks diyers.
Interesting is there are a couple other people in the thread saying the same exact thing as me and to check the voltages but somehow you guys have all latched on me as the bad advise giver. And then there’s those on endless sphere who will say the same. Really it’s pretty standard for figuring if a battery is damaged but we can’t have figuring happening around here it seems.
@hummieee nobody had a problem with old mate investigating his pack to see if there was something wrong with it. We encourage people around here to understand these types of things so that they know better for next time.
I’ll spell it out for you again, because you seem to have a hard time understanding.
The pack was bulk charged before any real investigation took place. For all we know, he could have had cells at 0v that have now been restored to a much better looking number.
While he may be able to discharge the battery and inspect again looking for anomalies, this is heading into pretty dangerous territory for anybody who isn’t willing to literally play with fire.
Therefore, around these parts, we encourage people to pronounce the pack dead after an event like this. Best practices would state that if there is a possibility the pack is dangerous, the pack is dangerous.
Nobody here is advocating for people to play dumb, just safe.
Edit: to make it even clearer, and just in case you weren’t aware and so you might take an opportunity to learn from this, most lithium ion cells are only considered safe between 2.5v - 4.2v.
Any cell that goes above or below these values has the potential to be permanently damaged. As there is no definitive way to prove that cells like this have not been damaged, we must assume that they are if we are following best practices.
bulk charging is not going to hide any damage
You can’t say this mate. You don’t know what voltage the cells were at before this happened. Just stop.
Wow. Besides that bull charging won’t hide the damage, which doesn’t seem to get through to u… talking about u personally: my stating he should check the voltage was also said by others above me but u said stfu and erase everything I write. And you’re still at it. Says a lot about u and how u work here as an admin
Think about it mate. Regardless of what voltages they were at, mate, they will be getting fed the same watt hours as all the other p groups so the loss is still the same loss. Does that make sense to u mate?
Just stop… think… then write.
Obviously seems they do as that’s all I’m saying to do. Open the shrink. Check with multimeter.
If u want to post dumb vids and play dumb that ur not actually “working” here as an admin… says more about u.
I wait for u mate? Does that make sense mate?
John.
Checking the pack with a multimeter after it has been charged does not tell us the voltage of the cells before it was charged.
Do you have some type of magic multimeter that does?
Let me spell it again for u since ur a fregin special admin who keeps erasing and maybe u erased what I wrote:
If u bulk charge all the p-groups will be getting the same watt hours so the variation STAYS. If anything the damaged battery would have more resistance and that would show up too. Does that make sense mate?
But I’ve said that many times. More interesting to me at this point is how ur actually an admin here
Nope, I don’t think you are reading what he’s saying
I’m reading just fine. And what I write stands.
The variation stays. Sure it might look better when it’s fully charged but bring it back down again and there’s the variation
What the funk are u even talking about? If u want to be simple go be simple somewhere and let people who are capable of understanding how batteries work do that.
Just play the “it’s too dangerous to even talk about” card. Get outta here. I had a night of that last night.
