Propel Endeavor S 2021 New Complete
Bought for GF she never used, only 15 miles on board
12s3p
custom Carbon fiber wrap
Gotta say she just absorbs the dirt and rocks!
| Length | 39 inches/1000mm | 39 inches/1000mm |
| Width | 17.2 inches/450mm | 17.2 inches/450mm |
| Height | 9.1 Inches/230mm | 9.1 Inches/230mm |
| Wheel Size | 8 Inches/200mm | 8 Inches/200mm |
| Ground Clearance | 4.4 Inches/110mm | 4.4 Inches/110mm |
| Maximum Payload | 330lbs/150Kg | 330lbs/150kg |
| Chassis | Independent Suspension | Independent suspension |
| Tyre Pressure | 2 Bar/29Psi | 2 Bar/29Psi |
| Deck | Carbon Fiber Deck | Maple Composite Deck |
| Board Weight | 40lb/18.5Kg | 37lb/17Kg |
| Electrical Control | ||
| Battery Pack Range | Rider A(75kg) 71km | |
| Rider B(100kg) 50km | Rider A(75kg) 45km | |
| Rider B(100kg) 28km | ||
| Battery | Samsung 25Ah/1110Wh, 12S5P | 15Ah/666Wh, 12S3P |
| Battery Weight | / | / |
| Shock Absorber | Adjustable 350lbs Coil Over Shocks | Adjustable 350lbs Coil Over Shocks |
| Motors | 2×6374 motors/ Each motor has a maximum theoretical output of 3000w | 2×6374 motors/ Each motor has a maximum theoretical output of 3000w |
| Transmission | 2xBelt Drive | 2xBelt Drive |
| Hill Climb | 0.38 | 0.3 |
| Recharge Time | 5h | 3.5h |
| Controller | ESC Based on VESC | ESC |
| Top Speed | 50Kmh/31Mph | 45Kmh/27.9Mph |
| Brakes | Regenerative Braking | Regenerative Braking |
| Manipulation Mode | ||
| Remote Controller | Wireless 2.4G | Wireless 2.4G |
| Speed Level | / | LO:8km/h; |
| MI:15km/h; | ||
| HI:45km/h; | ||
| PRO:45km/h(High torque) | ||
| Cruise Control | ||
| Controller High Voltage Protection | ||
| Low Voltage Return Warning | ||
| Remote Control Low Voltage Display | **: | |
| Price ($900USD): |
