So Prague updates. This event didn’t go smooth for me.
It started by blowing up an ESC the day before starting to drive to Prague. At Prague, on the Thursday Kartplanet session I didn’t ride at all, I was just working on my board the whole time. Swapped in a D100S, huge shoutout to @TZDKB for bringing it as my replacement part, after getting to the point where the only thing left was to do vesc config, I went to turn it on and nothing happened. From the quick measurements we took with a basic multimeter next to track, seems like the internal buck converter is blown, which should be fixable. So, in goes the other D100S that Tilo happened to have with him - by the time I managed to fully install this, change pinions, and run vesc detection, it was Saturday 3am.
So Friday I was running my mountainboard JumpBro on this board’s battery and 9x3.5 knobbies on Kartplanet. My times were, as you’d imagine, pretty darn slow. But I at least had something to ride.
Fast forward to Saturday, I went on the track with the newly repaired raceboard on lubricated fresh gears and even some HFI configured, although on FW 5.3 as per MakerX’s recommendation for stability. The torque actually felt great, which I guess would be due to lubrication.
I did manage to at least take a cool video using the above mentioned camera mounting setup.
Before my fall, my qualification time was 1st and the lineup was crazy strong. Qualification here is just your best lap in freeride - so with more laps I am sure I could’ve gotten an even better time. After my crash though, I dropped to 4th starting position. I skipped the whole race though.
I managed to record a video about how the wobble took me out.
Helmet took a pretty big hit, people were telling me afterwards that the sound of the helmet hitting the ground was scary loud. Helmet got cracked internally. Board decided to go crazy after the fall, remote is definitely messed up, have to do more diagnosis though.
I was knocked out for maybe 5 seconds, then 5 more seconds I was conscious but wasn’t in control of myself, then after that I just had a mild to medium headache.
Went to the hospital and got a CT scan just to make sure, and all is well, no injuries just gotta take the next few days fairly chill.
ECE 22.06 is a must for esk8! And I can stand behind the Sedici Duale as a very protective helmet… I think in a lesser helmet this would’ve ended way worse.
I think the cause of the wobble was not retightening my fresh bushings a couple laps after installing them, as I’m running new bushings now. They have definitely softened up, that said it doesn’t feel like if all preload would be lost.
93/95 cone, 95/95 fatcone.
47.5/17.5 angles on 120cm / 48" wheelbase. Standing platform about 30mm below axle.
But the bushings especially in the front are definitely on the super soft end of the spectrum. Ideally I’d have run at least 95/95 but that’d have needed more duro in the back too, and 100 wfb fatcones don’t exist as of now. Definitely need more experimentation. The wobble for sure came from the front. All my prior wobbles on Dualities were slow and easily controllable - this one was crazy strong and violent. So not sure what’s going on here exactly. @Titoxd1000 maybe the 47.5 front angle is doing weird things? Or just the super soft front bushing setup?
