Haven’t seen one happen clouds yet, not saying it can’t happen
Do you have more info on this or… Just curious. Someone else said the cores were gf nylon and everyone just ran with it. I made a couple comments that it might be easier to crack than PC/abs but I had no real testing data to back it up…
no adhesion issues with Cloudwheels, but still TPU is the best choice. For example Estaloc 59300 was the TPU material used by Kryptonics hubs back when they were still making Wheels. Kryptonics turned into AEND many years ago.
Dude. Why are you trying so hard to discredit individuals. The man clearly knows his stuff and he is clearly trying to help. You have a pattern of trying to shame people out of this discussion.
Remember this one…
You (wrongly) accused the rider who was injured that it was his own fault…
The manufacturer is behaving badly and the product is dangerous in it’s current state. No need to attack each other.
I’m no expert in this matter but this makes a lot of sense to me. And about bearing installation process goes. It also makes sense. Specially on cores like Abec uses witch seem to stretch out for easier bearing fitment
Now that you say it, it does looks smaller than 120mm…
But I doubt they will use kegel core…they already advertised it showing abec cores in their rendered photos…
Seems like that video is showing their new idea for retrofitting Iwonders to the outside of conventional hub motors. Notice the hub motors and the wheels streached 18 inches apart:
Pretty sure it’s just hooked to hub motor, quick and easy hack which does the job for a 10s video clip, and a 60kg rider, on flat ground. Looks like shit, so it probably is!
My board made very bad clicking sounds. Already replaced the bearings and played with belt tension but nothing worked. I just realized my cores are broken and the bearings are loose because of that.
