Broly
June 30, 2020, 3:44pm
#1
So I have a problem programming my esc.
So can program them With no problem, but the esc with the reciver work the other one no.
When I do scan can I get this see picture
Also if I turn off the board when I start again nothing work I have to do again everything
b264
June 30, 2020, 4:05pm
#2
Where did you get this build of VESC Tool from, and what operating system are you running?
Broly
June 30, 2020, 4:08pm
#3
I get it from vesc tool web side
The last version
On my windows computer
b264
June 30, 2020, 4:14pm
#4
Hmm, that’s the correct way to do it.
As troubleshooting, see if the newest build here does that
Since each build of the VESC Tool is compatible with only a few particular versions of the VESC Firmware, every now and then we find ourselves searching around for a place to download a precompiled executable of one of the older versions. When faced with this situation you either have to find it by googling, ask around on the forum, or download the source code and compile it yourself. All of these take time and can turn a simple task into a real pain. To remedy this, we have decided to crowdsour…
Broly
June 30, 2020, 4:15pm
#5
I will take a look thank you
Athrx
June 30, 2020, 5:55pm
#7
Control the canbus side from the bottom left corner.
From the connection tab you get that error for some reason
Broly
June 30, 2020, 5:57pm
#8
I think I did already what you say
Nothing come up
Did you really try at the other CAN Page? There is one page in the vesc tool giving that error like @Athrx mentioned.
The new vesc tool is somehow a bit weird. It took me 5 minutes to find out you have to choose the USB COM port by hand now if the correct one isnt in default.
Broly
June 30, 2020, 11:33pm
#10
I test other some different esc I have and all of them work
If I understand correctly what he say yes
Maybe some pictures will help
