After reading the garbage fire that is a certain thread on german hub boards, I have decided to share some research that I have been doing with the forum. I was always curious how different aspects of our boards and riding styles affected how much range you can actually get from a board. So I read a bunch of threads on here and the old forum and other stuff on the internet. The conclusion that I came to was that no one has released reasonably scientific practical testing results for Esk8.
So I decided to do just that. I found a nice testing area, setup a couple of profiles in Metr, and tested one aspect of range: Wind speed.
For any reasonably scientific test, the objective is to change one variable and keep all others as constant as reasonably possible. Considering that I donāt have access to a wind tunnel, large enclosed course or dynamometer, I canāt easily get separate aerodynamic drag and mechanical/electrical loss figures. So I have to use the total system power consumption. This test is meant to measure the power consumption in a ~13mph headwind and a ~13mph tailwind at different cruising speeds.
Hypothesis: Power consumption should massively increase when riding into the wind. When riding with the wind, power consumption will be very low until riding faster than the wind, then it should increase like normal.
For this test I used:
- DIY dual gear drive with Metr. (exact specs are not relevant to this test)
- 95Kg rider (me)
- Quarter mile long, flat, outside parking lot
- eRPM speed limiting using Metr (Note: real speeds were reduced slightly by voltage sag. Both speeds will be listed in results.)
- All runs were done in the exact same riding position, standing straight chest forward.
- All runs were done in a straight line on the same section of the lot.
- Results are an average of the power consumption at the test speed.
- All runs (except 5mph) were of the same distance
- The reference battery is a 10s2p 30q pack (216Wh). Most chinaboards that use this have a listed range of 12-14 miles at 15mph.
Now with that out of the way, the results of my test:
Results
Metr log
Headwind
| Speed (mph) | Power consumption (Wh/Mi) | Range (Mi) |
| 5 | 11 | 19.6 |
| 9.6 | 16 | 13.5 |
| 14.3 | 23 | 9.4 |
| 18.9 | 32 | 6.8 |
| 23.3 | 39 | 5.5 |
Tailwind
| 5 | 3 | 72 |
| 10 | 5 | 43.2 |
| 14.7 | 7 | 30.9 |
| 19.6 | 9 | 24 |
| 24.1 | 18 | 12 |
Conclusions
Headwinds and tailwinds can massively affect power consumption. It appears that the hypothesis was proven, as all the headwind data is much higher than the tailwind data, and the tailwind data starts increasing significantly above 15mph. Riding fast in a stiff headwind can halve the range of your board.
Future posts with more tests should be forthcoming, as I have already tested them, I just need to write them up. @longhairedboy
If you have recommendations for additional tests, comments on my methodology, or other comments for me directly, please reply to this post directly, tag me, or PM me as Iām not that amazing at following threads.
Edit: It occurred to me that I left out the most important part. The aerodynamic drag equation.
Drag = 1/2(air density) X relative wind speed ^2 X how aerodynamic you are (CoD X frontal area)
Please note how your speed relative to the wind is squared. This means that double the relative speed isnāt double the energy requirement to push the air out of the way, it is four times the energy.
But for the range discussion I disagree with you.
