I lowered this long ago to 35v cutoff start and 33v cutoff end. Its rare that I ever let the total volts drop close to 35. This issue will occur way before the pack is low though.
Before vesctool i was using the unity app and thats where this issue started. On the unity app i usually had motor max at 80a and battery max 80a. So that was 40a per motor and i was having the cutout issue.
I need a few more test runs with current settings. Im still hoping lowering the deadband was all i needed but it still doesn’t explain why it started happening with the unity app that doesn’t allow you to change it. I was using the android unity app.
The only other explaination I can think of is hardware failure. Im hoping not.
Ok so you guys were right. It wasn’t the deadband. It happened twice last night. First time I was at a stop then I tried accelerating on a slight incline trying to cross a street and it cut out for a second. The 2nd time I was moving slow and tried to take off to merge onto a street and it happened.
Im going to lower my motor and battery maxes both to 40a each side. I feel like this is going to be sluggish but I need to see what happens.
I rode last night with motor and battery max at 50a each side. It faintly cut out twice. Went home plugged xenith into laptop before turning off esc and checked for faults but it said none since start-up. If I had a loose connection would it have shown a fault?
Seems like the cut out was weaker with the amps set lower. Not sure if that indicates anything. This is frustrating.
I rode today and intentionally got it to cut out a few times so I could check for faults but there were none. I opened the cover of the xenith and didn’t see any burn marks. I didn’t remove the motor cable covers but I did pull on each one. None felt loose.
I was using two sets of extensions cables for the motors but I repositioned the xenith so I don’t need them anymore. I had to recalibrate motors though but that went fine. Hot glued the shit out of the wires. Everything looks good so I’ll ride tomorrow and report back.
Maybe the issue was with the extension cables. Idk.
I bet you simply added toooooooo much motor amps. I didnt read the whole thread, but If you go sensorLESS It could be. In theory you can add much more amps to each motor, practically, too, but the behaviour of the motor changes which means you can have different kind of problems bc of that. Heat f.e. is known problem everybody knows when adding more amps than rated to the motors. You theoretically get more torque but in practice it could be that you get problems at startup or/and at high speeds (full throttle).
Try lower the motor amps and get your battery amps in a rated area, too.
Problems should fade away, no?
Do you mean power cable to bms/battery or the power button for the esc? One of the wires to my power button popped out so it’s not working at the moment but the wheels roll esc to start so I figured why rush to fix it?
Ok so it happened again without my motor extension cables. I pulled down the covers of all the connectors for esc and motors and the solders look good.
If my belts are too tight can that cause it to feel like its cutting out? My motors have lots of torque so i keep them tight so they don’t slip. Im running out of ideas. Maybe i just need a more powerful esc. Maybe a motor cable is loose where they go into the esc. I cant remove those to look.
