Arguably the best bike battery and esc (true sine 72v) available for their power level. Both are potted.
Battery in maybe 80 duro pu and esc is harder.
With fuses  available for their power level. Both are potted.
Looks great
Not serviceable though
Just put it in the microwave for 30 min and u got the cells out watcha mean
I’m all seriousness… PU isn’t heat reactive is it?
If it has any watermolecules at all in it, it is. Tbh, I have no clue
What Linus is saying is that you should pour water onto the parts and then pot them. That will keep the water off the parts.
I am not 100% sure, but I think TPU (thermoplastic polyurethane) (or China 'Thane) you can melt, and thermoset polyurethane (or Cali 'Thane) that requires curing, you cannot melt it, but only burn it with enough temperature.
Yea “set” isn’t reformable w heat. Both are big thermal insulators and surprised to see cells potted when heat is a cell killer.
I imagine they’ve already tested this battery thoroughly but I wonder how a fuse would melt down while encased. Maybe would melt before pu deformed and would hold the liquid metal fuse in place. The cells’ pressure release valves aren’t going to function with the hard rubber holding it closed too.
I thought they’d at least pot the cells in some filled resin that would at least be a bit more thermally conductive then this clear/unfilled. Bet it reduces cycles and max amp ability.
Doing the esc w a heatsink imbedded seems great though.
I didn’t know about China thane, that was my understanding about thermoset thane. Thank you
tthe encasing pu intended to give the compression to the contacts wasn’t reliable. Was more interested in compression than potting
Ended the quest for compression connections after using rubber bands and 3D prints with copper sheet which worked nicely but not when crunched into a box on a board as other forces ended up releasing tension on cells…falling in and out of parallel again
