Well, if you make a 3D printed case for the whole thing, sign me up! I need to pair it with your 3D printed voltage meter pictured above
Cool. Ill work on it at some point in the near future.
I love the idea of this for repurposing underwhelming packs.
Plus you’d look like a boss on group rides while everyone is scrambling to find an outlet and you effectively pop an outlet out of your bag.
Will be following closely. I have a thing for junction boxes, electronics, and long range.
Is the general idea that the closer the output voltage of the portable charger is to the converters set output, the less work it has to do to boost it to the correct voltage and that equates to heat and probably eventual failure?
Yes! 10char
