2 posts were merged into an existing topic: Welcome to Derail Jail
Going to cross post here as this may be relevant. Evolve tires appear work on Janux 4.25" hubs.
added note.
this is quite interesting info from @BearHere so i’ll post it here
Evolve 6’’ can fit trampa superstars
Does anybody know the axle lenght needed for these hubs:
Looks like a cheap option with pulley for my MBS trucks. Maximum bearing to bearing lengt would be ~40mm
Does anyone know what the bolt pattern is on this hub? Trying to figure out if it will fit a kaly drive
Its the same pattern as rockstars
But is that the same pattern as trampa superstars?
no different
71.5 v 80.3mm pitch circle diameters
Uuuuuggh!!!
Anyone tried these 5 inch pneumatic wheels by chance? I’ve reached out to the supplier on Alibaba to see if I could grab a few to put on some 3D printed kegel core hubs for my DDs… I think 129mm diameter should be better than popping 150+mm tires on my DDs.
Nice idea was looking for some 4/5 inch pneumatic tires but still would probably be slightly to large for me as I got some 110kv dds
Can you link
Link isn’t working?
fixed
Since they are on alibaba won’t you have to order a large quantity?
Can you not by just a single set of 4 on aliexpress also anyone seen some 4inch ones
since TB tires fit MBS, Trampa, and Evolve hubs. do those tires fit TB hubs??
I believe so but don’t have them to be 100% sure. The 4" inner hub size is pretty standard.
