COUNTRY – USA, Ex Houston Texas – Downtown.
BUILD NAME: Rebuilt in 2022 The Black Wave 2WD
Price summary - Board with 2x M-Boards chargers and Red Hoyte Puck remote $1995. Paypal fees + boxing / shipping USA +$230 / Build is discounted over $1000 now and $0 cost on labor.
Wheel Base or total distance between axles - 42" or 1070cm
Board weight - approx. 24lbs or 11kg’s
- See Parts list Below and ignore prices as they are the old values- link to insta vid at bottom
See parts breakdown
BATTERY - NEW - OCT 2022 Molicel P42A 12S 3P – OEM by M-Boards P42A – M-Boards October 2022
MOTORS: 2 x MAYTECH MTO6374-190-HA-C, BLDC Motor with HALL sensor 190 KV with 8mm shaft & 3mm keyway.
MOTOR MAX CURRENT: 65A each. – Max Battery Discharge 126 A
MOTOR POWER: 3550W each – TOTAL 7100w – MAX Battery power 5443W
TRANSMISSION: Original 3D Servisas Spur Gear Drive 1:4 ratio - Straight cut gears, Mini Eco AT Gear Drive V2 fitting Infinity ATB / Trampa Superstar Hub
TRUCKS- Infinity ATB - Trampa Springs - Medium (red) Dampers front, Trampa Barrels with CNC Red retainers in rear.
RISERS – 3d Services 35 Deg CNC solid Billet MTB Truck Adaptor for long board.
WHEEL DIAMETER: 200mm / 8-inch primo strikers Tyres in near new condition – Brand new & unused Trampa Phat Lads hubs (Black), ultra-light, wide and these can take any size AT wheel up to 10” 3.75-4” hub diameter.
ESC: Flipsky Dual FSESC6.6 6.7 200A Based upon VESC6 with Aluminium Heatsink powered with a Flipsky 200A Anti Spark Switch. - Bluetooth Connectivity for VESC
REMOTE and PPM receiver– Hoyt Puck – Fire Truck RED – Best connectivity on market.
BATTERY TRAY – Carbon Fibre longboard enclosure “Oresome” By Trampa
CHARGING – M-Boards – 50.4 2.0 A
TOP SPEED – 70kmh/43 mph (Theoretical – lightweight rider)
RANGE – 48km/ 30 miles (Theoretical – lightweight rider on flat ground)
WATER RESISTANCE - Yes, enclosure is fully sealed with foam gasket and sealant and can take water splashes, but not waterproof and not for wet weather or riding in rain.
SHIPPING INTERNATIONAL EXTRA UPON ENQUIRY - VIA FEDEX
12s3p P42A Battery Pack _ Transparent Series — MBoards.pdf (51.2 KB)
20221013_MBOARDS_12S3P BatteryUSD.pdf (108.7 KB)
