Photon remote not functioning right
Someone with the photon remote got issues charging it? @Wajdi ??
Almost every time i wana charge it im stuck. Unable to charge it for like an hour.
First i have to disconnect it i press the power button a few times and leave it for half an hour unplugged before i reconect it and leave if for half an hour after that i am able to charge the remote not always tho… very frustrating.
When i power on my board before i power up he remote my board makes noise coming from 1 of the motors. When i go to menu and change signal to anything other then the lowest one to choose it also makes noise just like this until i change signal strenght to lowest one possible again. Maybe its the focbox unity i am using not sure.
Also i find the cruise control could get a patch.
When i am in cruise control mode which i have to change through settings which is fine. I have to press the safety switch button and accelerate to the speed i want to maintain. then press the menu button and im in cruise mode. When in cruise mode however i cant just use my brakes to disengage cruise control i first have to leave the menu before i am able to use brakes. I dont feel safe using cruise control this way since i need a few seconds before able to brake.
Also i would like to be able to change power saving mode to be on at 100 or 90% battery and not just at 30% or so
The telementry on the screen never shows my current speed which is not a bigg issue. but would be nice if working propperly i run a unity and i am told thats causing the issue.
Wajdi ghosted. Try him on contact@eboardshop.net but don’t hold your breath.
You can download the unity compatible firmware here, I manged to get all the binaries before the site went offline. Looks like it’s back online now but don;t see where to download them
https://drive.google.com/drive/folders/1fk-moapy6zytS9kYICwtpfawo4Y2_24c
Follow-on deep questions would be wasted on me, not affiliated beyond owning the same remote.
Happy trails, wear plenty of protection for what I would classify as beta controller really given the uptake and lack of communications.
